just put new power top cylinders/pump motor/lines in my 69. the aim doesnt have a section for vert tops??? anyone have a pic or diagram of how the pump lines run? Just tying to figure how to run at cylinders, my originals were cut when purchased...
just unhook the top bow and top cylinder bolt, unbolt the cylinder mounting bracket and drop the cylinder/bracket out the bottom as a unit. with the cylinder and unit out you can get to the outer bolt.
Im not 100% on that... My bow is bare right now. I would assume that if the top is up and latched this wouldnt be a problem, but maybe someone with more experience could help answer this.
