Has anyone purchased an HEI vacuum advanced canister where the end that you attach the vacuum hose to is bent at a 90 degree angle? I need a new canister that will not hit my head or firewall when adjusting the timing. I may try trimming or modifying the end in order to attach a 90 degree elbow. Any thoughts would be appreciated.
I use one with a 90 inlet. I think I pulled off a chevy. Been along time ago so I don't remember which one. And I don't know what the vac limits are but it works for me.
I put a wire inside and a hose on the outside so it wouldn't kink, placed a round file beside it and used pliers to bend it around the file. Had a bit of a time getting the wire out. Not pretty but works.
