Looking for some tips on a full trunk pan replacement. I have the rear tail off, and both rear fenders. The old trunk has been removed and I've cleaned off the frame rails. During test fitting, I found the full pan hits the supports for the trunk lid. Before I go cutting things, I thought it best to check around to see if there is a preferred way to slide that trunk pan in from the rear..
I done it a little different but I found some pictures on another forum that has removed the trunk lid supports. You will need an account with the website.
