My countershaft frame bracket did not come with any hardware to attach it to the frame. Does anyone know the specific hardware that is needed? I am guessing self-tapping screws because the holes aren't threaded and there is no way to get a nut to a bolt on the inside of the frame. Thanks for any and all assistance.
Not sure what you mean by countershaft. Do you mean the piece that holds the transmission to the frame? If so, they are attached by bolts, nuts, washers.
