#273903 07/31/13 12:25 PM
L
L Offline
I HAVE REMOVED THE KICK PANELS ON A 68 CONVERTIBLE. I AM LOOKING FOR THE MATERIAL THAT WAS BETWEEN THE BODY AND THE KICK PANEL. A THICK, PUTTY TYPE STRIP CAULK SUBSTANCE THAT SEALED WATER OUT FROM ENTERING THR [censored] PIT THANK YOU
LAS VEGAS
lasvegas #273907 07/31/13 01:43 PM
I recommend 3M Strip Caulk. I get it from Eastwoods. As opposed to the factory caulking that will harden, this stuff will always stay soft and sticky.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
salmon38 #274445 08/11/13 01:15 AM
The buytl used to set windshields works well too (no arguments about how one should use urethane not butyl on windshields).
go2fast #274476 08/12/13 12:54 PM
How did you manage to get the kick panels out without damaging them?
69 OHC ZH Sprint Hurst 3 Speed 3:55
OHC Forum http://sohcsix.yuku.com/
WANTED: 1969 OHC Sprint "H" Camshaft
OHCMarc #274499 08/12/13 10:50 PM
M Offline
no real way to put that into words... just go slowly and carefully and wiggle this way and that until it slides out. which it does. the danger spot is right where the big bottom part joins to the little vertical channel piece. just watch that area carefully.
you are likely looking for a better answer like, go up then down then sideways but I sure don't have that one. just work with the knowledge that they do come out in one piece, you just have to figure out the puzzle moves..
Mh68bird]
medhat68 #274500 08/12/13 11:06 PM
Last summer I purchase new kick panels and had a very hard time removing the original ones. I have recently taken my car COMPLETELY apart. This time I found that if you pull from the very front (toward firewall) and pull back toward seat it came right out. Not sure why but it came out very easy.
OHCMarc #274682 08/15/13 07:20 PM
L
L Offline
used a putty knife to carefully pry them out took about 45 min each
lasvegas #274754 08/17/13 02:58 PM
I
I Offline
3M Strip-Calk
Part No. 051135. - 08578 (Black)
20 yds. (60 feet) 1 foot lengths
Bought at NAPA
C
C Offline
Is the tube looking (the one that makes them hard to take out) on the back of the kick panels really needed wat r they for I was thinking of cutting that and just covering the hole
