67 with front drum brakes. I'm replacing the bearings and seals. I thought it was strange the the old seals came right out. I thought they were a pressed fit into the drum?
The new ones are the same, not a pressed in fit. This correct?
My thoughts exactly. I've never seen one fit with out needing to be tapped a bit. I'm wondering if there wasn't 2 different drum sizes with different seals.
Someone might have put different drums on but all the drums that should be compatible should had the same size seal.
Wonder if the drum got rimmed out or something from a bad bearing sometime in it 46 + years to not make it fit snug. Maybe the hub got loose at some time and caused the back bearing to ride in that area to cause it to enlarge the area.
Mystery solved... Went back to NAPA with the drum. Somewhere over the last 46 years the drums got changed to 68 or later. The seals are different from 67 to 68. Bearings are the same.
So someone replaced the drums at some point and either used 67 seals or the seals were replaced again at a later date and they never bothered to solve the mystery as I just did. I still need to take a look at the drivers front. But I have a set of seals for 67 and 68 now.
all early drum brakes i've seen on the GM cars had swaged (swed-ged) drums. the drum and hub assy were one unit and you used to be able to get replacements that way as well.
