Looking for the correct 67 throttle bracket for a q-jet. I'm also still running the original throttle rod setup. I'd like the correct one so that I can then mount the coil correctly. Thanks!
1967 Firebird Convertible 1980 Firebird Formula Turbo
Also if anyone has the original setup can you post a pic? Does anyone reproduce the setup? I have the rod, but the connection to the q-jet is not stock. Trying to go all stock under the hood. Thanks!
