Posts: 1,616 |
Can some one post some pics of where the bolts and studs go. I have a ac car.
Not sure where the double sided bolts go
john v.
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
Let's see IIRC there should be three. One on either side of the center ports on the drivers side used to fasten on the heat riser and one forward of the center port on the pass side used to attach the battery cable ground to.
Posts: 6,758 |
Don't know if this will help or not. My car originally came with A/C but engine was rebuilt and A/C was not reinstalled.
Of course then there are the head bolts under the valve covers that may or may not have studs on top for oil drippers depending on the year and if it came with them. I believe there were three bolts in the middle of the head on both sides.
Posts: 59 |
Not sure where the double sided bolts go I will try to snap some pictures this weekend, my card had factory AC, and still has the correct studs.
Posts: 1,616 |
john v.
2,110
46
