Does anyone have any insight on the best place to get a rebuild kit or any other advice?
I did find a video on the general things to do for a rebuild, but that was about it. the main thing I took away was that you need two guys to get the spring and washer back in correctly.
Are you sure it needs to be rebuilt? I was able to take mine apart, clean, relube and reassemble. And it didn't cost me anything but time. Shifts fine and haven't had any issues with it since. I would've liked to replaced one or two of the slide plates, as they looked abit thin but I will do it next time if there is one.
Proper alignment is 98% of the issue unless you know something specific is worn or wrong.
You guys may be right, it is still in the works. The guy I am buying from says he thinks it needs rebuilt- but I have yet to actually check it out in person.
I will definitely give it a once over before ordering anything. Hopefully it just needs some TLC.
Thanks Guys, I will keep those on file. 100.00 isn't that bad.
