#278493 10/30/13 05:14 PM
I plan on buying a new 400 hood.
After looking on line I found many different manufactures of the 400 hood. Not a big surprise. I assume they are all from the same stamping but sold to different companies.
I stumbled across a website that had four different options for the 400 hood.
http://www.restorationperformance.com/servlet/StoreFront
The four brands were Goodmark,Dynacorn,AMD, and OER.
After talking to a rep he commented that they sold more of the Dynacorn hoods and had good luck with them.
He also commented that more than likely they were all made at the same place, but was not positive.
The price varied from $365.95-343.92-306.95-269.96.
Has anyone bought an aftermarket hood lately? And if so do you remember what brand it was and how it fit?
Thanks Rob
Robert #278504 10/30/13 06:36 PM
Also was under the impression all the aftermarket hoods are stamped in the same place.
One important item is ALL the aftermarket hoods only work with the '68/69 style hood latch.
If installed on a '67, the hood latch needs to be changed out.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Robert #278510 10/30/13 06:59 PM
Thanks for the tip. I have a 1968 so I'm good.
salmon38 #278514 10/30/13 07:14 PM
Actually I have come across at least one repop mfr. that is making only '67 400 hoods. So just to confuse the matter, you need to be careful. I was not able to track down which one though. You need to look at the reciever openings before buying.
68tpls400 #278515 10/30/13 07:18 PM
I know where I can find a 67 latch! grin
Robert #278516 10/30/13 07:23 PM
Where? I took the last one you had...
I need another, so if you really have one, we need to talk...
68tpls400 #278518 10/30/13 07:28 PM
Just for information sake (fingers crossed that I never need one!) - which manufacturer?
1980 Turbo Trans Am
68tpls400 #278520 10/30/13 07:42 PM
Nope, I was talking about the one I traded to you.
salmon38 #278521 10/30/13 07:46 PM
Like I mentioned above, I was not able to track that down. Couple of Owners said "Oh, I bought it on Epay", and that's all they could remember. But they were definetly '67 style 400 hoods and were repops. I think I have come across three of them now. I also thought they only made '68-'69 versions until I saw those.
And for sure NONE of the repop hoods fit well without a TON of work. Also OEM hood scoops only work with and OEM hood, and repops only fit repops. So more to consider...
Robert #278525 10/30/13 08:04 PM
I thought I read some where on here where the fit of the hood was pretty good. But you had to do a little work on the front most center part.(beak)
Robert #285332 03/03/14 12:52 AM
N
New Member
New Member
N Offline
So has anyone used any of these hoods?
I'm thinking about this one.
http://www.restorationperformance.com/servlet/the-159755/67-dsh-69-Firebird-%22400%22-OE/Detail
As most people think they are all stamped at the same place, I figure it didn't matter which manufacturer it comes from but maybe I'm wrong? thanks.
