#285513 03/05/14 10:21 PM
will a 67 firebird hood swap with a 68 hood or do you have to modify anything?
thanks,
David
GADJIT #285514 03/05/14 10:25 PM
'67 and '68 hoods and latches are different.
GADJIT #285515 03/05/14 10:27 PM
is it the latch that is different or the actual hood?
GADJIT #285516 03/05/14 10:33 PM
both
GADJIT #285524 03/06/14 01:31 AM
can one be modified to fit the other? I have a 68 but may be buying a 67 hood.
GADJIT #285528 03/06/14 06:28 AM
The easiest way would be to get a 67 latch assembly
GADJIT #285554 03/06/14 04:28 PM
It will work, right? Just won't latch properly. I'm just guessing. Can't say I've ever tried it.
Firebob #285557 03/06/14 04:40 PM
Overall fit is the same. But if you shut a '67 hood on a '68 latch, you will never get it open without cutting or unbolting from underneath (some how).
GADJIT #285577 03/06/14 08:31 PM
Ahh. I see, said the blind man.
