My 68 convert is missing its spare tire and jack assembly. My phs doesn't say space saver was opted for, so i assume that it would have had a full size spare. What size rim did they come with and was it coded like the other 4 rims on the car? My car is a drum brake car with HG steel wheels.
Standard spare wheel was the same as the other wheels. (they used a normal 5 wheel rotation sequence)
Rally option came with five rallys. (one as a trunk spare)
Look at the placement of the spare tire tie down loop mounted to the trunk floor. A space saver has the loop welded higher, up the slope of the trunk pan. A standard has the loop welded closer to the bend in the trunk from flat to pitch (towards the well)
Make sense?
On my PHS doc option 702 is the option for Spare Tire- Conventional. From my research it was standard to have the Space Saver and you could have chose the Conventional Spare as a option.
