#286406 03/26/14 05:08 PM
I would like to get rid of some of my clutter that I have left after my restoration.
All of the items a useable or driver quality.
A prices include local pickup and shipping will need to be added.
68 NOS outside door fuzzies 2 piece door set. - 200.00
OE 68 AM Radio Nice and working - 150.00
OE Under Dash Heater Core Case Box- 100.00
Sold- 68 OE Dash Harness. Harness looks to be in good shape and wires not hard. All plugins are
there and marked. Only splice is the high low switch. No other skinned wires - 100.00 - sold
Sold- 68 OE Convertible Wire Harness with the Power Accessory Lead Wire and the Power Accessory
feed wire. Very good shape - 25.00- sold
68 OE convertible rain gutter - some screw holes cracked, - 25.00
68 OE transmission Cross member for (automatic turbo 350 , power glide , three or four speed
manual transmission) - 50.00
67-69 New Reproduction Transmission Cross member for (automatic turbo 350 , power glide ,
three or four speed manual transmission) - I had it powder coated and looks very nice. 80.00
OE Gas tank looks good inside. 20.00
OE 400 grills - newly painted and I have epoxied the usual break above outer headlight.
Driver quality No Trim . - 75.00 set
OE Side vent shut off elbows , deflectors and bezels- (46 years of dirt and nasty) - 25.00 set
OE Radiator Support Gusset Panels - need the lip repaired with nuts. - 25.00 set
OE Rear standard black seat belts. dirty. - 100.00 ( 3 male and 3 female)
OE Convertible B pillar brace- 25.00
OE Battery tray- 25.00
White windshield washer tank and OE bracket - 15.00
Rockers moldings - reproductions - driver quality - 25.00
Wheel moldings - reproduction driver quality- 15.00
Sold - New repro Lower baffle - fiberglass - 80.00 - sold
New Repro right trunk floor to 1/4 panel extension - 30.00
convertible Front windshield - 25.00
2 complete sets of control arms. 1 set is both left and right sides - 50.00 set
emblems - fender script, grill script, door panel birds, 400 hood.
-----Not 68 related----------
4 - Rally II rims 14x6 - blasted and painted - 200
(1) M5 3 24 KX
(3) M5 8 45 KM
New 650 CFM Four Barrel Model 4165 Spread Bore, Divorced Choke, Mechanical Secondary
Carburetor - 350
Two - 11 bolt timing covers good condition - 50 each.
69 sub frame maybe from a Camaro - dirty with surface rust. Body mounts holes look to have
been replaced, weld not pretty - 100.00
Here are some additional parts.
Convertible tack strip end pieces only good shape - 50.00
Convertible top rubber seals. No header seal just the middle and back pieces. Good shape. - 50.00
Two Square 69 style mirrors - 30.00
Trunk templates - Pontiac letters and 400 - 10 each
GM Hood springs - 20.00
New Engine mounts. Pair- 25.00
Old original engine mounts - 10.00
Sold- Pitman arm power steering - 15.00 - sold
Sold - Hurst plus shifter 4340 , flat shifter arm and knob , linkage and mounting bracket - 100.00 - sold
Power steering pump to block bracket ( needs heli coil on top bolt hole) - 15.00
Engine harness - lot of splices and hard wire. Good for plug in connectors only - 20.00
Rear harness - no splices usable for connectors or to use - 20.00
Valley pan- clean and painted has some pitting on top - needs a little metal work around the edges- 40.00
Saginaw manual steering gear and pitman arm - 50.00
Link to some photos of some of the items for sale. http://www.flickr.com/photos/silver-bullet/sets/72157638653297833/
I'll take the redlines for $40. smile
LOL. I don't have them on my list just wheels only.,
oh darn! I always tell my kids, "it never hurts to ask". grin
I am looking for the upper control shafts, I would be interested in one of your somplete setes if these are included?
Yes or I can sell you the control shafts. I have a set seating to the side. PM me if interested in either.
Thanks
HI. CAN YOU PM ME A PICTURE OF THE 67-69 CROSS MEMEBER THANKS
the original or the repop?
Hey Harold im interested in the following after looking at the pics:
Wheel moldings - reproduction driver quality- 15.00 (send me a pic of these in pm please)
do you still have the radio plate also?
can you PM me on these?
Updated list.
Driver quality No hockey stick Trim put does include a new repop "Pontiac" script emblem . - 75.00 set
OE Rear standard black seat belts. dirty and pitted. - 80.00 ( 3 male and 3 female)
1 complete sets of control arms- 30.00
Carburetor with custom bent fuel line - 350
got the parts wednesday, Thanx Harold,great doing business with you.
