Starting to work on the car again. Glove box has a light with orange wire which is activated by a plunger when the glove box door is open/closed. In that same general area I have a bulb holder with an orange and white wire going to it. In my case it is hanging down under he dash to the right of the glove box opening. Does anyone know where it mounts and what bulb it takes.
Supposed to be a metal bracket with hole in that holds the bulb and acts as ground, I think. Google Firebird courtesy lamps/bracket, you should find it. Mounts on both sides of corners under dash.
That sounds like the under dash courtesy lamp. It mounts under the dash, under the passenger dash vent close to the kick panel. The passenger door switch should plug into it. #631 is the bulb ID
