Posts: 442 |
My alternator belt has always been a problem. Going to try a different belt today. Any tricks here I'm missing? Didn't want to use any dressing spray.
Keith 68 Bird 428 Auto.
Posts: 1,480 |
Make sure you have the stamped steel pully on the Alt and not a machined one.
I swaped over to a 15xx series with a 17xx series so they ride at the same depth on the pulley. Solved my belt squeel issues.
Posts: 1,529 Likes: 41
Posts: 1,529 Likes: 41 |
No spray Try a different manufacturers belt, can also use some scotch Brite on the pullys. There may be some residue on them.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Hmmmm. I'm having an alternator belt issue too. Mine is squealing and coating the area with black belt residue. I've got a belt coming from Ames on Monday to replace the auto parts store belt. Likely will be the same belt. So there is an issue with the alternator pulley?
I can say that quality and materials are different from manufacturer to manufacturer.
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
I was actually throwing belts for awhile. Ended up being that the replacement alt had a different pulley. Swapped the old pulley onto the new alt and prob solved.
Posts: 442 |
Changed out the pully to get it to go away.
Posts: 94 |
seems I am having this issue as well. looks like the alt pully is sitting about 1/8th inch to far back. Not enough to throw the belt, but for sure squeals.
Posts: 1,363 |
I would also check that one of your other belts is not the wrong size. I had adjustment and squealing issues on my Sprint until I replaces all the belts per the attached chart. Found out someone used the wrong belt size and it affected my overall tensioning. It doesn't take much. http://thefirstgensite.com/library/partscounter/illustrated/pullybelt/pullybelt1.html
Larry 1967 Sprint Convertible
Posts: 94 |
thanks for that, but I will have to post a pic. as it seems the alternator is just a tad to forward so the alt pulley and water pump pulley are not aligned
2 members (Geoff, Jimc2002),
469
119
