Refer to Figure 12-7. From there it appears you have way too much loose wire on the dash harness side of that connector.
I would disconnect it again and then reconnect it above the steering column and then secure it out of the way either by making it run above some structural components, one of the welded on harness supports under the dash or with some tie-wraps.
