To those guys and gals that either are restoring their beloved first gen Firebird to close to factory what books / catalogs did you use?
69 OHC ZH Sprint Hurst 3 Speed 3:55
OHC Forum http://sohcsix.yuku.com/
WANTED: 1969 OHC Sprint "H" Camshaft
L
L Offline
67 Verdoro Green 400 Front bench w/auto on column
Now excepting- free, ready to bolt on, Pontiac Aluminum Heads...
Thanks to John(Hammered)-- This project is REBORN!!
http://s903.photobucket.com/albums/ac237/lupdiesel/
I didn't have much when I bought my Bird back in 1991, it was all in boxes, I used both the 1967 service manual and Firebird supplement and the Chilton repair and Fisher Body manual. Now Wow there is so much out there, I use Vicki's site alot and here the old posts help too.
Here's another one: http://tpocr.com/
It really depends on what you want out of your restoration. There are no specific Firebird resto books out there that I'm aware off, and the Camaro and a couple of others I looked at are IMO very vague and not very precise in the work described.
The best and NUMBER ONE advise I can give you is:
Do not finish-paint all your body panels individually off the car and then assemble and align.
Paint the backsides and even a coat of primer on front, but finish everything in one shot after you're happy with all your gaps and alignments. If it's not painted you can pry, hammer, shim, drop a wrench, rub you belt buggle, set a beer bottle on it etc. and it won't hurt a [censored] thing .
Everything else was a combination of service manual, this site, and other sites when finishing mine. Hope this helps.
Since you have a '69, I would get a copy of the '68 Firebird Factory Assembly Manual from E-bay.
Not the most legible documents out there, but better than nothing. Shows you how they put the car together at the factory.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
I have a 69 Assembly Manual. Is the 68 better than the 69 manual?
I believe it's printed a bit better. Unfortuately, '67 & '68's are much more compatable with each other than '69's so it's probably won't help you out that much more.
1980 Turbo Trans Am
