I am getting close to complete on my 68 400 4 speed Nightshade Green Firebird. I have been following several others here and thought I would just do a quick update and hope for others to do the same.
I need to do:
Remove door panels and adjust window's
Hood insulation
Trunk mat and spare tire and jack resto ( still need a inflation canister)
Install counsel
Install rear axel snubbers
A major detail job with a buff and wax
A few other small things but I am wide tracking!
Gordy
1968 Firebird 400 4 Speed
68FB400
Installed front fenders and started messing with the wiring on my 68. Hope to be up and running in 2 weeks. Still need all the door weatherstripping, headliner, seats recovered.
last touches to getting it to a driver status.
It will be one year at the end of this month since I bought her. Seems every time I get it back on the road another issue pops up. Right now, trying to figure out why it burns through header gaskets. First time, the ones that came with Doug's headers, 2nd time, Felpro and this week, Copper gaskets going on. :-(
1968 Firebird 400 coupe
verdero green/blk interior
Up a running here with minimal interior and exterior parts on to just make it drivable. The exterior has been media blasted and primed for an eventual paint job. After paint, the entire interior and exterior trim go back in/on.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Finished installing the sail panels in my coupe over the weekend. Other than some minor tune up issues, she's 99.9% done!
Finished painting the jack and tire iron on the Aleutian 'vert. Once I get those installed she's done for the year. Found a correct th400 for her last week. Plan to rebuild and install next spring. Just need that pesky tube and dip stick! Scarlet has been done for a few years now.
Need to adjust windows and finish installing interior.
I have been driving the car off and on all summer.
Made it to my first car show this year.
After six months of gathering parts to start on the body work on the 68 I finally got started on the. Teardown and started the body repair process. The person who had done the body work prior was not good at dent removal so he used a thick coat of bondo to cover it up and level it out. Once I got it down to bare metal I found small dents that should be easy to pull and skim coat. Going to look at color chips today
P
P Offline
Well I have not worked on mine in a couple of years. Life has had other plans for me, hoping to get back on it this winter. When I started it I told everyone it was my 20 year project. For those of you that have not seen it I put a link to the thread.
https://firstgenfirebird.org/forums/ubbthreads.php?ubb=showflat&Number=261515&page=1
I don't really fall into this category but all I need is to get a few more horses (like 150 or so) and I'll be all done.
Mine has always been a driver and keeping her going while locating parts is a full time fun job. I landed a spare OHC a little over a year ago and have been restoring parts to rebuild the spare motor and then install it to then rebuild the factory motor. Haven't had much luck finding good pistons.
Right now I am wanting to sell a motorcycle plus everything that goes with motorcycling as I am hanging up the bars. If I can raise enough funds I am striping the car and getting the body work done and painting it the factory Windward Blue.
Other than that I still have the mile long lost of things I am always fixing.
69 OHC ZH Sprint Hurst 3 Speed 3:55
OHC Forum http://sohcsix.yuku.com/
WANTED: 1969 OHC Sprint "H" Camshaft
T Offline
Body is on rotisserie ready to be media blasted, look to have in body shop by late fall...
NOS easy! smile
Ha, true. Too easy. Not my style. It's the hard way or the hiway for me.
M Offline
I am getting closer I took it over to a friends today to get the glass in and head light bezels on and lined up
10660922_10204803515507063_1942638538_n.jpg 10695002_10204803564228281_1247821300_n.jpg
[Linked Image from i64.photobucket.com]
Tim Malmstrom
Lookin Good!!!
M Offline
Thank you
Tim Malmstrom
I'm confident I won't have it running this weekend for sure. Interior completely sandblasted ready for primer. New floor test fitted and ready to go in. Full firewall next. At least I've changed direction from disassemble to assembly. Maybe next summer.
20140828_224803.jpg 20140827_113052.jpg 20140827_113123.jpg 20140827_162925.jpg 20140827_113150.jpg
You having that work done in Mexico? Pics look like kilos of coke under the back seat.
Thanks to all who participate. I finally got the counsel in along with the clock. I had it rebuilt and did not go with a quartz movement. It has kept perfect time the last 24hrs. I plan to unplug the wire harness at the fuse block when not using the car for more then a few weeks. Today i am planning to go for a drive to Hugo MN for a hog roast & car show. Gordy
68FB400
No, just good ol jugs of sand from sweden. Used to fill High Voltage cable splices. Had a lot left over from a project in NJ. Working great as sandblast media.
