Hey Everybody, I am looking to find a couple of front coil spring insulators for the 69. Does anyone have a part number and dimensions that I can use when I call?
If you need just the rubber, I can't help you. Maybe goose will see this post
Kyle
Having recently gone through this here is what I was able to find. The global west spacers will do the trick. I really wanted rubber as its insulation purposes would give a good feel. Problem is nobody makes a 5" spacer they show a listing in several places but when it arrives its 5 and 1/2 inch in diameter. You may be able to squish them inside the perch to make them fit but I've not tried. I searched for camaro isolators as the aftermarket favors them. The global west spacers are made of soft aluminum and fit right in. When the weight of the car comes down they conform to a custom fit. The install took less than an hour. Jack it up. drop the shock. Put an inside the coil compressor in and draw it up about 1/3 the way. Slip in the spacer and align it with the end of the coil. Lower spring and put the shock back in. Quick and easy. If you don't have an inside type compressor you can rent one from most auto parts stores. I got mine off summit for $45. Feel free to pm me with any questions as I just got done with adjusting my springs. -goose
