I'm not sure what happened to the previous post I asked on this so I'm trying it again...
But, will this console from for a "67-'69 Camaro work with our Firebirds? And is it safe to say most parts if not all interior parts will work with our Firebirds? Ideallu, I would like to install a double DIN system in the front there.
1968 Firebird 400 Metallic Green; Balanced 400 engine with H beam rods, Speed Pro forged pistons, steel crank, Ram Air IV GTO cam, and a Edlebrock intake and 750 CFM carburetor
there does not seem to be any access port or hatch for the rear mounting bolt. so it will not mount "factory" style to the normal mounting points. but almost anything that will fit over a tapering hump will go in that spot. You just have to decide how non-stock you want it to look and then decide where to drill the holes into you tunnel.
Great, thank you for the advice! I am not looking for the stock look so this may just suit me well then.
