Needed more gear, topped out around 135-140 but still had a blast. One guy came by the pits and said: "You may not have the fastest car out there, but dam sure the coolest" That, made my day.
If I go back I'll have to make some changes, definitely not set up for the speedway portion, worked well on the infield section.
Man, that would have been the thrill of a lifetime.
wow that's awesome. Is your car prepared to go 180-200? Seems you'd need some expensive tall gears to get there and then se if the body/frame can take the load.
