I have everything off the subframe except the transmission and I don't really have an easy way to take the transmission out at the moment. In hindsight, I should have pulled the tranny when I pulled the engine... Was not planning on going through front end, but started in on it and kept going further and further...
I was thinking about just supporting the tranny and dropping the subframe, but I've never done that before. Seems problematic to get the subframe lined back up unless I actually pull the tranny too...
Support it with like a roller jack of some sort and use some blocks to support sub frame and pull the sub frame bolts and you should be able to roll it out as long as you still have wheels on the sub frame.
thanks. I was pretty much assuming there was no way to do it, at least I couldn't figure one out.
Wheels aren't on the subframe at the moment. Just one of those things where I kept finding more issues in the front-end until I was suddenly down to the subframe with my tranny still attached. Live and learn.
I hear you ... I really enjoy the project start & tear down. My wife likes the big finish!
