I'm quite positive the brackets are different. One thing I know the attaching hardware under the dash is way different. Maybe the bracket(s) on the column can be switched, but do your homework to make sure. Frank.
It's a direct bolt in but you must use the correct ignition switch for a 69 Pontiac with tilt,the part number ends with 093. The wire harness plugs will have to be twisted 1/2 turn so they can be plugged in. You should also get the Pontiac style levers to look correct. I've done the swap many times.
Thanks! Is this a DIY project that can be handled for the weekend warrior guy?
