There are either speed nuts on the inside of the quarters, or there are compression pins through the metal with the louver pins pressed through them.
If speed nuts, remove them then remove the trim. If compression pins, you need to pry them off with a putty knife or screwdriver.
Yeah, you'll have to take the panels off and the steel brace. Then get a 3/8 nut driver and remove them. I bought Ames replacements that are decent, but if you're particular like me, you'll notice they are a little narrower than the stock ones. I kept my OEMS and maybe someday I'll find a guy that can re-chrome pot metal for cheap.
