Rubber for me. As it's section not seen, did not feel the need for steel braided. I run steel braided from the pump to the carb for insurance and looks. Bare in mind, that section you are referring to is a vibration isolator.
I use rubber and steel braid from the pump to the carb. Puting AN fittings on the end of the steel line just to run braid to the pump did not make sense to me. When I replace the pick up and the metal fuel lines from the tank it will have AN fittings and I will put a steel braid in that section.
