The boss on the front subframe, which makes contact with the lower arm bumper, is welded on my car. In the illustrated parts index it shows a (#20) reinforcement assembly (lower control arm bumper bracket) bolted to the frame. Anyone know why the difference or have any insight/info on this?
In '67 the bumpstops were indeed bolted to the subframe to the rear of the spring pocket. In '68, the bumpstops were welded to the subframe to the rear of the spring pocket. In '69, the bumpstops were welded to the subframe in front of the spring pocket.
Thus the reason why mixing control arms and subframes could ruin your day and why aftermarket control arms have multiple bumpstop locations on them.
