#297697 04/23/15 07:35 PM
Anyone know if the crank pulley for an A/C car was the same as the non-A/C car?
My setup is from a 69 car.
rohrt #297700 04/24/15 12:18 AM
No, not same.
rohrt #297709 04/24/15 08:42 AM
rohrt #297716 04/24/15 12:28 PM
Thanks Harold,
I assume there must be a 1/8" difference between the AC and non AC pulley?
I'm pretty sure I used a AC pulley and put one of the pulley supports plates on the back side as a shim. I plan to change out the harmonic balancer so I will find out what I have.
My crank pulley has a wobble so step one is to change out the harmonic balancer. Needs done anyway.
That will tell me if the pulley is bent. Most likely is.
