Looking at replacing FL factory caliper with hairline crack. Best deal I've seen is from Rock Auto. Anyone have experience with this company? Seems considerably cheaper than other companies calipers.
I use rock auto a lot. They are fine. If you order a bunch of items you have to watch shipping. Sometimes they may sent a bunch of parts from many different warehouses and shipping starts to get expensive but it shows you the details in the shopping cart.
If its cracked you will have to replace it, depending how old the other caliper is, I would replace the rubber hose and rebuild the caliper at the same time.
It's for a '68 so 4 piston. rock had them for about $90 after core return. Going to try the one first and see how it performs. On the smaller side as far as overall cost for budget, but I do know all the smaller things start to add up.
