hello all. I just installed a new brake booter in a 67 firebird. [ it was non power ] and i need to no the right hole in the peddle to use and also i need to no how long the plunger rod is?the one from non power is too short. mike0861@aol.com
plunger on master side of booster can be long or short, to match a deep or shallow master. If you have a short rod and a deep master, you can get a pushrod spacer, or change master/piston, or pushrod. pics and info on master/pushrod relationship edit: fixed link to pozziracing.com
