Need some help! I just finished replacing floorboards and started fitting a new stock exhaust to my '68 400 only to find the LH & RH exhaust manifolds are wrong. I understand the correct manifolds for a non-HO are 9777755(LH) and 9794320(RH). Does anyone have these? Is there any other numbers that will fit - 400 stock exhaust?
Thanks for your help.
What do you current manifolds look like? I need some for an A-Body and could maybe use these, and may have some out of a 69 bird lying around.
