Hello all. I have a 1968 cope that I am installing air conditioning (Vintage Air) into. I am needing to splice the vintage air violet wire into my ignition wire. I need to find the ignition wire that only gets 12v when the ignition is hot. So I should be able to eliminate the brown ACC line, the red BATT line and the dark green GRD line. However, there is a pink IGN line, a black KEY- line, a pink with double black stripe KEY+ line and a purple with double white stripe SOL line.
I believe the pink line is your feed to the coil. This would only be hot when the ignition is hot. The pink with double black is neutral safety switch for a starter interrupt.
I know that washing and waxing my car with the present condtion of my paint is like polishing a turd.....but it's my turd and I want it polished!
That pink/yellow lead to the ignition is only at +12 volts when the starter is energized. During the run mode, there is only 9 volts or less on that pair of wires due to the resistance wire in the pink lead.
You can get switched +12 volts from the fuse block under the dash from a terminal near the center of the block labeled "IGN". I would guess the A/C system needs more amperage than the pink/yellow leads could provide, anyhow. Also it needs 12 volts.
If you don't feel like hacking into original wiring harnesses or snaking wires through the firewall you can always use a relay to give full battery voltage and use the original resistance wire for switching the relay.
Hank, do you want to splice into the ignition wire or a wire that is switched 12 volts when the key is on? As stated above your ignition wire is not 12 volts, unless you've switched to an HEI. The pink/black is the ignition wire but it has a resistance dropping the voltage to 6-9 volts. The yellow wire from your starter to the ignition coil is 12 volts but only when the starter is engaged. There is a dark green idle solenoid wire that is 12 volts with the key on. There is a black/white idle stop wire that may be hot with the key on. I don't know if these solenoids are used on your car but the wires and connectors should be there.
