ok another easy one I hope. Again have to ask before I get a BFH.
Fixing trunk floor so need to remove cocktail shakers - they dont quite seem to want to slide out.
Is there a trick? Which way should they tilt out? I assume tilt feet first towards the center of trunk? If so I'm gonna need a mallet I think. Just dont want to damage anything.
1968 Fbird Conv - Well its mostly there. 8) - mine 2015 1979 Camaro RS - Summer DD - mine 2013 Now where did I put my flashlight? ;(
I don't mind scraping anything at this point - just don't want to damage the (now I understand to be almost irreplaceable) shaker or bend the lip of the trunk that the bracket is around. I'll try the 45deg towards the rear.
One came out ok - the other is by a worse spot in the floor and it just wont come out. I'll probably end up cutting the floor around it out - although I noticed that underneath the shaker is a reinforced piece attached to the frame. I wonder if they make that support piece.
I know my reinforcement plates have a stamped ID on them. I would find another way to get that out before you cut that. Should be able to tilt them and slide out?
