I use Global west weld on subframe connectors. They bolt on the front and are welded on the rear. I noticed a lot less roll and sway immediately after I installed them. I use Competition Engineering traction bars, they work well also. Can't speak for other brands as have not used them.
The hotchkis ones are on sale in their eBay store. There bolt in style. Think there 299.99 buy it now. I've been more than pleased with all of there products. That being said I've also have had great luck with global west
I did a lot of research and went with Global West also. They have not been installed yet.
As an engineer, I liked their reasoning for their design - they made a lot of valid points for it. They weld to the rear frame rails instead of utilizing the front leaf spring pocket bolts which they pointed out are too small to handle the loads from both the springs and the subframe connectors. They don't like the idea of welding at the front in case there is an accident and the subframe has to be removed to be replaced or straightened.
I've been running CE frame connectors ( bolt in) for at least 20 years. Have been glad they were not welded in at least a couple times. Can't say if they are better or not as good as fully welded (I suspect fully welded is as good as it gets ) but they work fine bolted in. Never had them come lose or cause any problems. My experience says bolt in. You got a welder? Are you going to have to have somebody else weld them in? Are you going to be able to take them off if you have to? Just some food for thought.
The one's from Paul/Ram Air Restorations are actually someone else's. I've forgotten whose name was on the box when it was shipped.
There is something to be said for having a removable connector. I put mine on before I painted. Since I painted I have had the hood slightly touching the cowl panel. Moving the hood forward caused the hood to touch the bumper bar. I've adjusted the front end as much as possible but it's still too tight. Now I will loosen the front subframe and move the whole assembly forward a half inch, even though the alignment holes in the frame and body line up, I will have to move everything forward to have the sheet metal good. I'm glad I don't have to cut the frame connector off to do it.
