Can anyone refresh my memory. Will a 3.08:1 gearset fit into a B.O.P housing/carrier that has 2.56:1 gears ?. I read somewhere that certain gears only fit certain carriers but cant find the post.
They are described in the rear axle section of the factory Service Manual for your year. The info is different for locking and non-locking differentials. The info for '67 suggests the answer in your case is no.
Salmon38 that PDF is interesting. And confusing for me.
I always used this reference.
There were 3 different ratio 8.2 Pontiac 10bolt carriers for both single track & Safe-T-Track usage High ratio = 2.56-2.78 Mid ratio = 2.93-3.08-3.23 Low ratio = 3.36-3.55-3.90-4.11-4.33-4.56-4.88
Keep in mind that for the 8.2 Eaton only makes the Low ratio. Not sure about Auburn. I see they offer a chevy unit that works with 3:08. Are the Chevy and BOP Auburn units the same?
