I just installed the new chrome windshield molding.....did I screw up....I have a new rear view mirror and can't figure out how it mounts........Was it supposed to go on BEFORE the chrome moldings?
The rear view mirror mounts to a bracket on the inside of the car. It would have nothing to do with the exterior windshield chrome.
The 68 rear view mirror mounts or screws from the underside where that hole is, I assume the 67 will be the same. Turn the bracket over and se if it aligns with the holes under the windshield frame. The 68 has a plastic trim piece that slides over the bracket and screw into that screw hole in the center of that big cut out covering that big hole in your picture.
