Has anyone found a good match for Cameo White amongst the spray can and touch up sticks found in auto supply stores? For example, is there a current GM white that would match up? I have some small touch ups that I need to do.
Jeff, You might call this place: http://towerpaint.com/automotive.html They sent me a couple spray cans of solar red, although I have not used it yet. Jim
Thanks to Scott Whitty in Welland Ont who provided codes that will work for the correct match paint from Canadian Tire Corp. Unfortunately, after checking with CTC they are discontinued, there is no cross ref or replacement. Does anyone have extra's of these that they'd care to share? Spray: 47-3639-4 GM 69-91 11 White Tube: 47-9401-2 GM 71-87 11 White
