Those are hard to find. I paid quite a bit last year for a '68 version. It did have the heads, but no carb.
Yes, engine unit number is 6 digits, like 521962. I didn't right it down, but can get it tomorrow if it tells something. I thought the number was just unique to the car.
It is short block with waterpump and triple crank pulley, and timing cover, intake - off. All internals suppose to be original. I thought of tearing it down to check no.s and make it easier to move around.
ok, the motor number is 521956. Thanks for the info. I haven't decided to keep it and find a set of heads. I had a 67 lined up last year to put it in, but it fell thru. Now. someone wants to trade parts for it.
Thanks for all the info. Wanted to post it here first in case any members needed one.
I have a B097 water pump (good) and I'm sure the pulleys I just pulled it all of my 67 400 I won't be using, timing cover wasn't good enough to keep so I pitched it. Just sold the 670's
