Posts: 95 |
After switching from points to HEI, I got my tach to work by running a new wire from the distributor. Now my hood tach is not accurate. Shows idle at 200 rpm and I hooked up a new tach to test which shows 900 rpms. Is there a cheap way to fix or do I have to send it to RC Tachs? Thanks!!
67 Firebird 400. 30k orig miles, 4 speed, ps, pb, pw, front disc brakes with dual piston calipers, ac, hood tach, triple black.
Posts: 16 |
Mine didn´t work at all after change and no matter what we did we couldn´t get it to understand new signal from HEI. I had to order repro tach. Works perfect.
Riku 1968 RA I
2 members (Geoff, Jimc2002),
469
119
