I'm putting all the electrical, vacuum lines, brackets(coil), shifter and fuel cables back on my engine and need some nice closeup pics of an original setup for a non a/c 4 barrel car as a reference, any help would help, thanks.
You can get a lot of pictures and ideas if you would search eBay for other 69's. Many of the parts mags have detailed pictures too. Year One has some good ones. There are plenty of car shows this time of year, take your digital camera. If you don't already have it, a repair manual helps too. Jim
Hey, when you hook up your pcv valve from the lifter valley cover, check to see that one cylinder isn't getting more air than the others. I have an Edelbrock performer intake with a quadrajet. I feel that the fitting whichconnect the rubber tube to the intake is a little to close to the number 2 intake runner, causing cylinder number 2 to run leaner than the rest. if you have any info or thoughts on this theory, I'd like to hear them.
