Hi All,My question did they make 2 different bat wings on the 69,.the body shop cracked the one I had,Found another bat wing but it is different. both have the same numbers.One weighs more than the other,one is hollow and the other is solid Where the rubber is bolted on. Has anybody come across this. Thanks Jim
I've had mine since around 2000, not sure about the numbers I have mine installed right now, but they are a different material, the original is a plastic and the repop is a solid sandable fiberglass
