Hello, Could you'll help me out...how do you remove the chrome trim and rubber weatherstrip from the rear quarter window on a 1967 firebird? Does the window have to be removed or can it be done in place? Starting to get warm out and want to jump on some projects. Thanks, Rob
The trim is secured with clips and will have to be removed with a special tool. The window is sealed in with beutal. If its dried then it will come out with some work but otherwise will have to be cut out with a wire.
They were demonstrating the use of this tool over at Detroit Muscle (Power Block TV) on a recent episode involving a fire engine red Nova.
