I picked up a set of boss rims. 18s in the front and 20s for the rear. Clearance is not an issue but I was told extended studs would be needed because of the larger diameter rim. Is this true or will stock studs suffice?
Don't forget rims need to be centered on the hub Bolting a set of aftermarket rims on without the adaptors that center on the Hub leads to vibrations The studs are used just to hold the rims on the car and not for centering the wheel.
