I have a firebird restoration nearing completion and need help with the vacuum connections. Unfortunately, I did not disassemble the car. Is there a diagram out there somewhere or does someone know how to connect all of the vacuum lines. I have the a/c vacuum lines done and connected to the vacuum can----but where does the can connect to?
That helps, but, where at the carb does the vacuum can connect to. I saw one photo that used a fitting that replaces the right rear bolt for the carb to the intake manifold. Is that what I am missing?
