Anyone have a junk rear bottom seat frame they could remove a couple springs from? A front bucket might even work, I'm trying to repair my front bench in my 69 and a couple springs are missing parts and can't weld it together. The rear bottom is close enough to make work and I've never looked at a front bucket. I only need 1 or 2 and maybe some short lengths of the larger wire. Thanks
You could buy some new springs. They sell those things by the foot. (I replaced the ones in my Challenger seats.) You can mail order them or just try a local upholstery shop. Just look for some with about the same size wire.
Didn't see seperate ones in all the catalogues but just ended up pulling some from a 66chevelle and shaping them, what I needed was rear seat springs from a 68-69 since they are almost perfect for a front bench
