Posts: 36 |
Converting a 6 cyl Bird to a V8, changing all fuel lines and sending unit to 3/8. Any trick or method to get the longest metal line, the tank to pump in position?
Thanks, Mike
Posts: 1,529 Likes: 41
Posts: 1,529 Likes: 41 |
It just takes time and patience Last one I did was folded up like a pretzel from shipping and I had to fight with it to fit up against the floor and get into the clips.
Posts: 36 |
Patience yes! Actually had to walk away for a moment. Came back, ended up disconnecting the rear shock, front bracket on leaf spring, and rear brake line. Once the front half was situated, the rear went right back, with a help from jacks and pry bar.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
I have vague memories of the struggle. I did stainless which made it worse because it's stiffer. I get OEM steel lines now.
Posts: 442 |
My first thought was, I don't know if it would be possible to do without a lift?
Keith 68 Bird 428 Auto.
2 members (Geoff, Jimc2002),
469
119
