#309037 10/28/16 09:41 PM
M Offline
Converting a 6 cyl Bird to a V8, changing all fuel lines and sending unit to 3/8. Any trick or method to get the longest metal line, the tank to pump in position?
Thanks,
Mike
Mike C. #309040 10/28/16 11:02 PM
It just takes time and patience
Last one I did was folded up like a pretzel from shipping and I had to fight with it to fit up against the floor and get into the clips.
Mike C. #309058 10/29/16 08:55 PM
M Offline
Patience yes! Actually had to walk away for a moment. Came back, ended up disconnecting the rear shock, front bracket on leaf spring, and rear brake line. Once the front half was situated, the rear went right back, with a help from jacks and pry bar.
Mike C. #309059 10/29/16 09:00 PM
I have vague memories of the struggle. I did stainless which made it worse because it's stiffer. I get OEM steel lines now.
Mike C. #309061 10/30/16 12:14 AM
My first thought was, I don't know if it would be possible to do without a lift?
Keith
68 Bird
428 Auto.
