Posts: 81 |
Bought a 400 out of a Catalina. Was told it was a 72 and never apart. Block number is a 1971 400. Tore the engine completely down for a rebuild. Heads have casting 98. After reading it says its from a 71 455 so that tells me the heads were changed. Question is I was planning on Edelbrock heads but after seeing this should I rebuild these 98 heads for the car. Looking for a great weekend cruiser not a race car. Car has 3:55 gears and a locker. Thanks.
Posts: 2,113 Likes: 1
Posts: 2,113 Likes: 1 |
114 cc (nominal) small valve heads that will put your compression ratio at 8.5 or lower. Personally, I think you can find a better starting point.
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
Basic economics really. Edelbrock's will cost you min $2500. A good set of iron heads will be less than a thousand to buy and have rebuilt to new. And you can pick your compression ratio based on the chamber size of the heads you buy.
Posts: 1,529 Likes: 41
Posts: 1,529 Likes: 41 |
As well as you can buy dished pistons these days to put the compression where you want.
2,192
74
