Anyone know a decoder for an original build sheet? I got all the VIN info already as that is easy to find and decode. I need help with lines 3 thru 6 and the Fisher Trim Options. Mine is about 85% good to read, just need some help with the codes. Thanks and sorry if there is already a post out with this info. I looked for about an hour and gave up.
If you were to request all of your factory documentation from Pontiac Historical Services, they will send to you a build sheet decoder along with those documents.
Otherwise, any other '68 owner could decode your build sheet using their "cheat sheet" if they also requested their factory documents.
