When you guys say stock, i would think that means copper not titanium or platinum etc, correct?
I been trying to find a chart on Ac delco plugs but can't find a list. I wanted to see a list and figure out the differences. have seen comments about using a "hotter" plug etc, trying to understand it.
Thanks bill v
69 Firebird Convertible (wifes car since 1979) Goldenrod Yellow, 350, plain Jane Car was stored in garage since 1990
I need help, if anyone see's I'm going down the wrong road--Straighten me out!
Don't get caught up in all the spark plug hype, Rock Auto has the R45S plugs that will work just fine in your application. Other fancy expensive plugs weren't designed for these engines, stick with what the engineers picked.
Whats the difference between R-45s and R-46s plugs?
And a general knowledge question:
Dr, in the rock auto page you posted. They talked about copper core and the performance of heat transfer to the plug tip. So, does that mean that heat generated by the spark sets off the combustion or is it the electrical charge that does it?
I've heard people say "use a hotter plug" I wondered what that meant.
Thanks bill v
Hotter refers to how well the spark plug transfers heat out of the core.
Colder plugs would be used for engines with higher cylinder pressures, ie compression, turbos, superchargers, they are more susceptible to detonation.
In a gas engine, the spark always ignites the fuel/air mixture, unless you have detonation issues caused by timing or excessive carbon build up in the cylinders.
Although this is from NGK, the basic theory is the same.
Large gaps .040-.045 is ok if you have a decent electronic ignition system that has some power. For a factory points set up .032-.035 is maximum. A larger gap builds more resistance on the factory points system. I have been using the r44-r45 heat range on all these engines. You wouldn't use a r46 unless you have a worn out oil burning engine that you just want it to make it down the road.
