Looking for a pair of the vertical, Chrome quarter glass trim that the weather stripping slides into that fits a 68 Firebird. I believe it is the same for hardtop or convertible, 67-69. and Firebird and Camaro. Driver quality is fine. Thanks.
I bought a new set with rubber inserts for my '68 last year but only used the driver side if you are interested in the other one. I did have considerable difficulty installing it as the rubber inserts are apparently not the same thickness as the original material, and would not stay on. I ended up removing the glass and having the trim piece installed at a local glass shop. Better access to the screw at the bottom too. Hope you have better luck than I did. Let me know and I can give you a price.
